- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBS750 boot-loop... just blinks white.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi All
RE: RBK752
My 750 Satellite has gone into what appears to be a boot loop.
My main router is fine.
The RBS stopped connectivity to my TV/Cable boxes 3 days ago.
- i have power cycled it
- i left it off for a few hours
- i hard reset it (10 secs, orange blink)
My RBR still will not 'see' the device. Will not sync voa webpage or app.
The power light on my RBS is green
The blinking white is slower, then faster.. then it starts again.
I assume its a boot-loop.
How can I tell when my RBR auto updated firmware?
Has any heard of firmware bricking routers?
It's currently plugged in to the RBR, and no activity lights on the NIC.
(cos "it's still booting")
Any tips and tricks are greatly appreciated.
The last step will be to hard reset the RBR... but I dont wanna really do that.
Thanks 😁
Bevvo - Perth, Western Australia
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
a firmware fix for the RBS issue >
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/RBK750-and-850-Series-Firmware-Versi...
@FURRYe38 thanks
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBS750 boot-loop... just blinks white.
What happens if you connect the RBS to the back of the RBR using a ethernet cable?
Does the RBS appear with a IP address on the RBRs web page under Connected Devices?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
