Hogwarts's avatar
Jul 28, 2020
RBS850 assigning new IP addresses to existing devices that were assigned a static IP address
I have the AX6000 RBS850 which i have had for a month.   Its a nightmare.   One of the issues is that i have a list of devices that need to have static IP's so i assigned them.    I have had to reboot the router a couple of times and despite having a static IP assigned to a MAC adress it gives it the IPAdress of aother device and then i have to reboot those devices or it brings my network down.
Plus you still cant get extra satellites.  So sadly i third of my house is offline  anyway.   How do i solve this.  How exactly could it do this?  THEY ARE ASSIGNED.
  • FURRYe38's avatar
    By static do you mean set on devices or as in IP address reservation set ON the router. There is a difference.
    I've got v32 loaded on my and both RBS are ethernet connected. IP address reservations for the RBS and 1 wired PC. DHCP IP address pool on mine is set for .100 thru .150 for my needs. I on'y have about 30 devices. I have a few cameras, printers and NAS which at set to static IPs outside the DHCP IP address pool. Everything else is Dynamic IP addressed assigned.
    • Hogwarts's avatar
      Hogwarts
      Guide
      MY DHCP adress range is the default 192.168.1.2 to 192.168.1.254.    and my  Firmware Version is
      V3.2.15.25_1.3.15.
      under the advanced tab "attahced devices"   i have added about a dozon adress reservations.  They are in the same range as the default.    Are you suggesting that the router will step on "RESERVATIONS" because they are in the range?    I woudl hope not.
      • FURRYe38's avatar
        No. Reservations should be with in the routers iP address pool. Static IPs belong out side the pool which you don't have room for that.
