Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBS850 which port Connect Ethernet?
- Mark as New
- Bookmark
- Subscribe
- Permalink
2023-03-05
01:45 PM
2023-03-05
01:45 PM
Hi - when hard wiring an Orbi rbs850 satellite to the router does it matter which of the four Ethernet ports on satellite you use?
None seem marked with an inbound feed indication like with router?
Solved! Go to Solution.
Message 1 of 4
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
2023-03-06
05:50 AM
2023-03-06
05:50 AM
Glad you got it figured out. Might mark it solved so others aren't still trying to fix it
Message 4 of 4
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
2023-03-05
02:19 PM
2023-03-05
02:19 PM
Re: RBS850 which port Connect Ethernet?
You can hardwire (ethernet) your backhaul to the Orbi satellite using any of its port: https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-Sy.... On the Orbi router side, as the picture shows connect to one of its LAN ports (not the WAN port).
Message 2 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2023-03-05
02:55 PM
2023-03-05
02:55 PM
Thank you! Figured out I had a bad Ethernet cable which is why o was having an issue.
Message 3 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2023-03-06
05:50 AM
2023-03-06
05:50 AM
Message 4 of 4
Announcements
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
