Orbi WiFi 7 RBE973
Reply
Router not connecting to modem anymore
Premorange
First my Orbi app showed that the router is disconnected from the internet, but the satellites were still connected. Weird. I’ve reseted the router, now it does not connect to the internet anymore at all. My internet has not changed.
Message 1 of 4
ekhalil
Master
Re: Router not connecting to modem anymore
1. What Orbi do you have and what firmware is it on?
2. What is the make and model of the ISP router to which Orbi router is connected?
3. Are the satellites wired or wirelessly paired with the router?
My Setup Internet Fiber ONT 250↓/250↑ISP Telenor | Wifi Router Orbi RBR850 + RBS850 + 2x RBS750 + 3xRBS350, Wired/Wireless BH / Orbi RBR50 + 6x RBS50 + RBS40V + RBS50Y, Wired/Wireless BH | Switches NG GS208Time Zone CET (Sweden)
Message 2 of 4
Premorange
Hi, thanks for the quick reply mate. It’s a RBR750 router, bought December 2021. No idea about the firmware, it doesn’t let me go to that point. The two satellites are not wired. Thanks!
Message 3 of 4
Guru
What Firmware version is currently loaded? Log into the RBRs web page at 192.168.1.1 with a PC and web browser to find the version.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 350 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
