- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
Upgraded Orbi router - CenturyLink can no longer connect
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Upgraded Orbi router - CenturyLink can no longer connect
So ethernet connected to ports 1 and 2 you have problems and then plugging into ports 3 and 4 on the RBR you don't have problems and things are good?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Two different 960, both with bad ports, seems unlikely. I suppose it could happen if a bad batch got out.
I would test those same ports with a different device/computer and different jumper cable. In fact, I'd use the plainest old CAT5e cable you have or even CAT5 if you have any relics. And I say that because in my testing, short patches don't really matter. I have used 10' CAT5 cables from the 90s as a test and they work fine. Even the cable that comes in the box with the 960 is only CAT5e. At any rate, there has to be some weird combo going on there...or that unlikely as heck, bad batch of 960s. I have CAT5e all over our house and maybe even CAT5 - whatever they were using in 1996 when it was built! 😄 And my 960 and wired SATs work like a champ.
Good luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That's correct. Anytime I connect to Ports 1 and 2, I do have a connection, but it's extremely slow. Speed test fails every time, always. Google.com takes about 1-2 minutes to load. Browsing websites with images is slow and images never load. They always show a broken image icon. When I mean slow I mean painfully slow. I wish I could tell you the speed, but the test fails every time.
Ports 3 and 4 have no issues. But this happened on the original RBR 960 and the replacement
- Mark as New
- Bookmark
- Subscribe
- Permalink
Seems like if this is happening on two different 960s, something your connecting to ports 1 and 2 maybe causing problems?
What is the brand and model of the device and if this is a PC, what is the brand and model of the ethernet adapter?
And does this happen with only one device or happens with others?
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's the MacBook Pro I mentioned earlier. It does this on all devices though. No matter what I plug into Ports 1 and 2 it's the same. Plugging in a Orbi satellite, a PS5, Apple TV, Windows PC, same issue occurs. Even plugging these devices into the satellite that's plugged into ports 1 or 2, same issue.
I've tried everything I can think of but no luck
- Mark as New
- Bookmark
- Subscribe
- Permalink
Has NG support responded to your feedback with this problem being seen across two RBRs?
- Mark as New
- Bookmark
- Subscribe
- Permalink
So any updates or progress on this? 😉
- Mark as New
- Bookmark
- Subscribe
- Permalink
It seems there is a bug with the Orbi 960 and 970 Series with CenturyLink PPOE. I switched my ISP to Quantum Fiber since CenturyLink is pushing it heavily in Seattle to switch. Now that I've switched to Quantum (which doesn't use PPOE) I have had no issues. Hopefully Netgear can resolve the bug for other CenturyLink PPOE users.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Great to hear. Thank you for letting us know.
Enjoy. 📡
- « Previous
- 1
- 2
- Next »
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
