Orbi WiFi 7 RBE973
Reply
WiFi 6 icon is on my Samsung S21 BUT Orbi RBRE960 Attached Devices shows Connection Type as 5G
Elwood_85
None of the other devices attached show 6G even though they are newer devices that are WiFi 6 capable.
The Orbi only shows 2.4G and 5G but no 6G . Should there be a 6G icon in Attached Devices Connection Type?
I am not running any Satellites just one Orbi RBRE960, residential single family home Firmware Version
V6.3.7.5_3.2.25
Your help is appreciated
Please see attachment
Message 1 of 11
Accepted Solutions
Mikey94025
Hero
Re: WiFi 6 icon is on my Samsung S21 BUT Orbi RBRE960 Attached Devices shows Connection Type as 5G
You're confusing wi-fi 6 (which is still 5Ghz) and wi-fi 6e (which uses 6Ghz and the separate radio in your RBRE960).  From https://www.tomsguide.com/face-off/wi-fi-6-vs-wi-fi-6e-whats-the-difference:
  1.  Wi-Fi 6 can send and receive data over both the 2.4- and 5-gigahertz (GHz) bands (Wi-Fi 5 is 5-GHz only) and can move even more data by running a single ultra-wide 160-megahertz (MHz) channel on its 5-GHz band.
  2. Wi-Fi 6e added more than a gigahertz of fresh electromagnetic spectrum space in the U.S., ranging from 5.925 GHz to 7.125 GHz... This additional block of spectrum, generally referred as the 6-GHz band
The Android screenshot just indicates Wi-Fi 6, not 6e.  From https://www.androidauthority.com/wi-fi-6-910014/ : If you see a number 6 alongside the Wi-Fi symbol, it means that your device is connected to a Wi-Fi 6-capable router.
Message 9 of 11
All Replies
CrimpOn
Guru
The WiFi Alliance did no one any favors by creating such confusing names.
WiFi6 refers to an improvement over WiFi5 for devices using the 5G Frequency WiFi spectrum
WiFi6E refers to to use of the 6GHz Frequency WiFi spectrum
Devices labeled WiFi6 are built to use 5G.
Message 2 of 11
CrimpOn
Guru
Message 3 of 11
Elwood_85
Just so I understand better, in Attached Devices -> Connection Type I will only see Wired, 2.4G and 5G icons but no 6G icon even if devices I have are WiFi 6E capable like my Samsung S21 is and my daughter's new iPhone are 6E capable?
Thank you CrimpOn
Message 4 of 11
CrimpOn
Guru
This article from last October does not list any Apple iPhones:
https://www.techietech.tech/wifi-6e-compatible-smartphones/
Message 5 of 11
Elwood_85
No. mine is the Galaxy S21 5G (Sprint) and according to Samsung Specs are Wi-Fi Connectivity
802.11 a/b/g/n/ac/ax 2.4G+5GHz, HE80, MIMO, 1024-QAM  With 802.11ax being 6E   right?
Thanks again CrimpOn
Message 6 of 11
Guru
2.4G+5GHz this doesn't include 6Ghz so the phone does not support 6Ghz. AX is a wifi MODE not a FREQUENCY, a mode that is seen on 2.4Ghz, 5Ghz AND 6Ghz.
Message 7 of 11
Elwood_85
I understand what you are saying but did you see the attachment in my original post? The white WiFi 6 icon (black background) is a screenshot taken directly from my Samsung S21 5G Model SMG991-U
I really appreciate your help Thanks
Message 8 of 11
Mikey94025
Hero
Message 9 of 11
Elwood_85
Ok. NOW i get it. Wow. I am certain a lot of Android users are going to think that they are on WiFi 6 because of that icon. Kinda seems like false advertising to me.
I did a experiment a few minutes ago. I turned on the 6GHz only radio in my Orbi and had the password different from the 5GHz. I then disconnected my Samsung S21 from Orbi 5GHz and refreshed available networks on my phone and my Samsung S21 did NOT see the 6GHz Orbi network at all.
I really appreciate CrimpOn, FURRYe38 and you Mikey94025. Thank you for explaining this in a way that I could understand.
Message 10 of 11
Guru
Glad we got that ironed out.
Enjoy now. 😉
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 57833 views
  • 6 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
