Must_Function's avatar
Nov 19, 2021
how to set up Orbi AX6000 (RBK854) & EAX80 to CAX80 Router Modem
I have a one story 4000 sq ft house and 500 long ft driveway going to my horse barn. I have cat 6 ethernet throughout my property going to middle of my driveway and to the barn. I have ip cameras, TV streaming, gaming and several portable devices. The setup I have right now is very unstable with frequent drops in internet. I have very poor cell signal, so I need wifi assist on my phones. I really like the CAX80 wifi coverage and speed, but I need reliable and consistent wifi expanded throughout my property. I just purchased ORBI AX6000 (RBK854) for the house coverage and two EAX80 for driveway (have cat6 & power wired to weatherproof box in the driveway) and barn. How to configure CAX80 with ORBI AX6000 and EAX80 for best coverage. I will have two Orbi satelites connected via ethernet and one wirelesly. Both EAX80 will be connected via ethernet.
  • plemans's avatar
    The orbi won't do 500ft. Neither will ethernet. Ethernet maxes out at just over 300ft. Unless you have a switch or something in there to pick up the signal and rebroadcast.
    For that range, your best bet is a point to point system.
    And then you go over having an LTE hotspot but wanting a CAX80.
    Do you have cable from an ISP?
    Who's your isp?
    this is all a bit disjointed.
    • Must_Function's avatar
      Must_Function
      My isp is Comcast. Yes, I do have powered switches every 100ft. I do not need LTE. since my cell service is very poor,  I use wifi calling on my iphone and it has worked just fine for several years. I want to make sure that I get consistent wifi signal. I've had the CAX80 for 10 months and it has excellent wifi coverage, but I need the wifi coverage expanded in every corner of my house so I don't loose signal in certain areas. I need to know how to configure CAX80 to work with Orbi in my house. Since CAX80 is a router modem combo, I am wondering if the CAX80 is better router than the Orbi router. Which should I use as the main router and which should I enable AP mode. Most devices on my property are ethernet connected and they function fine, but I am trying to get a good and reliable wifi coverage throughout, for all my wify devices like ipads, iphones and wireless laptops. Any suggestions?
      • FURRYe38's avatar
        For your size of home only, 4000sq ft should only need the CAX80 and maybe one or two extenders. When I had my CAX80 running in router mode with wifi, I used two EX7700s to help cover my 5000sq ft home. No problems.
        I also have an Orbi 8 series and works well with the CAX80 in router mode or in modem only mode. I use the CAX80 mostly in modem only mode and when I use the Orbi 8 series, its in router mode, however also works in AP mode as well. RBR and two RBS.
