- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
"good" vs "poor" backhaul status
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does anybody have any insight into how the web UI diffferentiates between "good" and "poor" backhaul status? My light shines blue on sync; the speed off the satellitre seems fine (c. 300 up down - and although I have a 1G line, I'm not fussed about a satellite at the end of a daisy chain producing 300) and yet on the web UI it switches between "good" and "poor" backhaul status. I assume it has something to do with RSSI and noise levels, but I'm intrugued that a blue light can also be "poor". (on the semi-useless mobile app it shows as green)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: "good" vs "poor" backhaul status
What orbi do you have? (model)
You put their daisy chaining?
It could be the satellite switching from a daisy chain connection to directly connecting to the router.
also in AP setup: RAXE500->EAX80
1.4gig download/100mbps upload from Xfinity
We’re members of the public helping out on our own time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
850 with two satellites. The second satellite has no possibility of connection with the router: I pick up only signal traces from the hidden channel with a sniffer. It connects to satellite one which itself has a good 5gHz connection to the router.
Satellitre two glows blue on setup and much of the time appears as "good" but sometimes appears only as "poor". Yet devices connected to it seem fine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Dd852 wrote:
I assume it has something to do with RSSI and noise levels, but I'm intrigued that a blue light can also be "poor". (on the semi-useless mobile app it shows as green)
Unless I am mistaken, the "Blue Light" appears for only 2-3 minutes when the satellite first connects to the router, and then turns off. Orbi systems periodically survey the network and the connection may vary over time (and be reported as 'poor', then 'good', etc.) The light will not come back on unless the connection fails completely (magenta).
Technical details would be fascinating to know, but my guess is that whichever engineer inside the company actually knows them is not likely to share them.
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
- Mark as New
- Bookmark
- Subscribe
- Permalink
@crim this makes a lot of sense. There must be some wavering in the signal due to ... whatever interferes with 5gHz that's just enough to periodically knock it into "poor" but not bad enough to break the link. I do wish Netgear was more forthcming with data - it would be great to actually see an RSSI reading rather than a vague term of "good" or "poor" - but I suppose this is the price one pays for being a "copnsumer" product rather than a "semi-pro"
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You could use powerline or moca (ethernet over coax) as a wired backhaul.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks. I'll investigate Moca. I found powerline not a good solution, or at least having one satellite powerlined and one on wirless backhaul wan't - mobile phones got knocked consistently offline going from one zone to another (I suspect some kind of weird mis-match in the communication back to the router)
