MikeG63's avatar
MikeG63
Apprentice
Sep 14, 2023
Access Control Lists for Orbi RBR50
In recent days I have experienced issues when existing devices have tried to reconnect to my router.  It turns out that the problem was my ACL list had reached a maximum allowable of 128 devices in the allowed list.  I turned off ACL and the problem went away.
As I only have currently 32 devices connected my question is can I clear out my ACL and strat over, and if I did do this would there be any detrimental effect on my existing devices or would a simple reboot re-populate the allowed list as I have ticked allow new devices to connect to the router.
I have an Orbi RBR50 with two RBS50 satellites connected to it running the latest firmware.
Any help would be very much appreciated.
Many thanks
Mike
    • MikeG63's avatar
      MikeG63
      Apprentice
      A reboot doesn't clear the ACL as far as I am aware
  • CrimpOn's avatar
    CrimpOn
    MikeG63 wrote:
    As I only have currently 32 devices connected my question is can I clear out my ACL and strat over, and if I did do this would there be any detrimental effect on my existing devices or would a simple reboot re-populate the allowed list as I have ticked allow new devices to connect to the router.nks
    Mike
    The router keeps a list of every device that has been "Allowed" and every device that has been "Blocked" so that it can recognize a device when it attempts to connect again.  Clearing these two tables in the Access Control menu page simply means that any device that is not currently connected will be treated as "New".  With the setting to allow new devices, that means the table will grow gradually over time.  Rebooting does not change the contents of the table. So, if the table is cleared out, then it will remain cleared out when the system reboots.  If some new devices are added to the table, then they will remain in the table after a reboot.
    • MikeG63's avatar
      MikeG63
      Apprentice
      I'm guessing then from what you say that if I clear my allowed and blocked ACL lists, and selecting allow new devices to connect my existing devices, after a reboot, will then simply re-connect which will populate the allowed ACL list and I can then monitor the ACL and block any unrecognised devices in the unlikely event that scenario occurs.  I am tempted to just turn the ACL function off as it's super unlikely that someone will try to hack my password and gain control.
      • CrimpOn's avatar
        CrimpOn
        Your choice.  I have never enabled Access Control
        • Because of the complexity of my WiFi password, and
        • Because most of the forum posts regarding Access Control are regarding issues, rather than praise.
  • I have the same issue and tried also to disable the access control but after a reboot it turns back on and again some new devices are blocked by Armor access control.
  • It is very frustrating Netgear cannot fix the issue and cannot provide a solution, I had also bought Armor and that is the real issue.
