× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
Blue Light Orbi RBS50Yv2 But Not on Map
BroDoug
Guide
My Blue Light Orbi RBS50Yv2 was working yesterday and has been a couple of years...
This morning it didn't show on my Map...
Firmware is V2.7.3.22
I have Orbi Router RB50...
2 other satellites shows in the map  with the router...
I have a blue light on Extender but not showing on the map;
What would be the next steps to complete the connection
Message 1 of 10
Accepted Solutions
Guru
Re: Blue Light Orbi RBS50Yv2 But Not on Map
In orbi mode, its the devices themselves (your phone/tablet/etc) that choose which to connect to.
And give it some time. It sometimes takes device a while to swap. Try going to that location you wanted coverage and see if that device connects/switches to that satellite.
Message 10 of 10
All Replies
Guru
Not sure what you're referring to with "blue light". A little better description of whats going on might help.
Are you able to access it through its ip address (find it in the attached devices list)
Message 2 of 10
BroDoug
Guide
I did the setup of power to the Orbi Extender:
Power plugged in and did not turn it on...
Held the Sync Button and pushed power on/off button...
Power came on...
Continued to hold sync button until white to blue flash a couple of times...
Then released the sync button..
It went through several flashing blue...
 Then blue stayed on steady...
I checked my app and router shows and two other satellites that I have shows up and are working:
But nothing on the extender shows up...
But the blue light on extender stays solid blue...
Orbi Router is RBR50
Orbi Exstender is RBS550Yv2
This had been working for about 3 years until this morning...
Map usually showed Sat. 2 connected to extender with great speeds...
 Thanks Doug
Message 3 of 10
Guru
Message 4 of 10
BroDoug
Guide
That was my intention to have it on extend mode, nut it is not working.
Before it would extend my wifi out to my garden about 300' feet away and had a very strong signal.
The blue LED stays on.
I have went through the same process of setup several times.
Any ideas why it is not working.
Message 5 of 10
Guru
Why not put it in orbi mode and sync it with your orbi system?
then it uses the dedicated wireless backhaul. You'll have faster speeds and lower latency.
Message 6 of 10
BroDoug
Guide
I was just trying to get it back like it was for a little over 2 years when it was in extend mode and I could stream my Spectrum on my laptop in the garden whoch is 300' from the back of the  house... And the router is still another 30'...
I think the Outdoor Orbi must be malfunctioning because nothing hooks up to it at all.
Message 7 of 10
Guru
Try putting it back in orbi mode and re-syncing it.
Message 8 of 10
BroDoug
Guide
I changed it to Orbi mode. It shows it is connected but none of my devices have connected to it. Even standing within 5 feet of it my iPad connected to my kitchen which is 50 feet away.
Message 9 of 10
Guru
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 2621 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
