Orbi WiFi 7 RBE973
Reply
Can I connect an Orbi RBS350 Satellite to an Orbi RBR20 Router...?
masemasemase
The router (RBR20 - Firmware V2.7.3.22) is running in AP mode.
I also have a hard-wired satellite (RBS20 - Firmware V2.7.3.22) which is running well.
The guy at the store searched online and told me it would work 😞
Any help would be much appreciated.
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 5
Accepted Solutions
CrimpOn
Guru
Re: Can I connect an Orbi RBS350 Satellite to an Orbi RBR20 Router...?
No. He is incorrect.  (i.e. full of s**t)
Check the product data sheet (online)
https://www.netgear.com/images/datasheet/orbi/RBS350.pdf
Page 2 under "What do I need?" Orbi router RBR350.
None of the AX products are compatible with the older 802.11ac product line.
Message 2 of 5
All Replies
CrimpOn
Guru
Message 2 of 5
masemasemase
Bugger - thought that would be the case. Should have trusted my gut.
Thanks for replying. I'll stop troubleshooting now and put it back in the box.
Message 3 of 5
masemasemase
Hey @CrimpOn. Me again.
Nobody seems to sell the RBS20 anymore. Do you think the RBS50 would work with my RBR20?
Message 4 of 5
CrimpOn
Guru
All of the original Orbi residential satellites will function with the RBR20 router:
RBS50
RBS40
RBW30
RBS20
RBS40V
Satellites from other product lines are not compatible (Pro, AX, the "10" series, Nighthawk)
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1489 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
