Orbi WiFi 7 RBE973
Reply
Changing Guest Lan IP subnet
safejunk
Star
So I saw this solution for a Orbi RBR850 and I thought someone with a RBR50 was able to do this as well, but I have a RBR40 and a RBR20 and while it takes the commands and keeps them after I reboot, connecting my Laptop to main net work and iPhone to Guest Network simply does not give me the differet pool IP I expected......These were the commands....
  • nvram set lan1_ipaddr=192.168.3.1
  • nvram set lan1_gateway=192.168.3.1
  • nvram set lan_ipaddr2=192.168.3.1
  • nvram set dhcp_start2=192.168.3.2
  • nvram set dhcp_end2=192.168.3.254
  • nvram commit
  • reboot the router
  • Set the LAN IP address to 192.168.2.1 in the Orbi web GUI under >> ADVANCED >> Setup >> LAN Setup
But on Router, I get this..... no change on the network
1
IPHONE-XR
192.168.1.3
192.168.1.3  2.4G Guest
2
Windows PC
HPLAPTOP
192.168.1.2
192.168.1.2  5G
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 4
Accepted Solutions
CrimpOn
Guru
Re: Changing Guest Lan IP subnet
I seem to remember this was one of the "significant differences" between the WiFi5 Orbi and the new WiFi6 Orbi.  What a lot of people thought should be "obvious" (i.e. putting Guest devices into a separate IP subnet) was not part of the original Orbi firmware design.
I think you are destined to be unhappy until (and if) Netgear changes the Orbi firmware.
Message 2 of 4
All Replies
CrimpOn
Guru
Message 2 of 4
Guru
Please post about this over in the Orbi AX Forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
 Thank you.
  • nvram commit
  • reboot the router
1
IPHONE-XR
192.168.1.3
2
Windows PC
HPLAPTOP
192.168.1.2
192.168.1.2  5G
Message 3 of 4
CrimpOn
Guru
The question is about doing this to WiFi5 routers, so this is the correct forum.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1630 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
