corradokid's avatar
Nov 20, 2018
Disabling WMM Disables N? FW V2.2.1.210
While turning off WMM for both 2.4 and 5GHz in Advanced Setup -> WiFi Settings to see if my LIFX bulbs will stop randomly dropping the network, I noticed with WMM off my late 2011 MacBook Pro saw all access points as 20MHz 802.11a (for 5GHz) and 802.11b/g (for 2.4GHz) only, connecting via 802.11a at <50Mbps. Turning WMM back on shows 802.11ac for both frequencies. Very strange and makes me question how well thought out/labeled these settings are? 2.4GHz is set to auto channel, 5GHz is 48 (why not auto select?) and 20/40 MHz Coexistence is enabled, have 8 other networks visible around me, and ethernet backhaul to 2 satellites.
QoS is turned off, though I wish this feature was fully implemented (ridiculous for a mesh setup costing over $400 to not have more customizability.)
Holding my breath for a dd-wrt or tomato open firmware for these fairly powerful units... would be nice to use the back-haul radios as extra signal as they're useless using ethernet backhaul.
  • Thank you, very good observation.
    Now I understand why the WMM settings were recently moved from the QoS part in the Orbi web interface to the Advanced Wireless settings.
    WMM was introduced in 802.11e which was an enhancement to 802.11a (5GHz) and 802.11b (2.4GHz), so it seems that what Orbi does when you tick off WMM is to remove support for all advanced standards after 802.11a and 802.11b and keeps only 802.11a/b/g
    WMM (Wifi Multimedia) -if implemented correctly- enhances quality of service (QoS) on a network by prioritizing data packets according to four categories (Voice, Video, Best-Effort and Background).
  • Have you had any luck with your LIFX bulbs? I have a couple that keep dropping off the network and need to be re-setup probably weekly. The rest work fine but it's always these two, and I've even moved the bulbs around to where other ones are plugged in, but sure enough they keep dropping, so I don't think it's the pysical location of them (they're central anyway and have a strong signal).
    Just curious because it's a bit of a pain and I never had these issues when I use my Amplifi setup instead of Orbi.
    • FURRYe38's avatar
      Review this to see if anything helps?
      https://community.netgear.com/t5/Orbi/Orbi-and-FEIT-2-4GHz-IoT-wi-fi-bulbs/m-p/1664260/highlight/false#M45442
      • dkleinknecht's avatar
        dkleinknecht
        Star
        Thanks for the suggestion, unfortunately this doesn't seem like it will help. My issue is that I'll have all my bulbs connected and working fine, but then seemingly out of nowhere a couple of them will just drop from the LIFX app and will need to be reconfigured for my wireless network. So I'll go through the process of reconfiguring them and they'll show up again for a bit, but then again out of nowhere they'll drop again and I'll need to reconfigure them.
        The thread you linked me to seems to be if I couldn't get them to connect at all, which isn't my problem. Thanks though!
  • FURRYe38's avatar
    Can try this:
    Advanced Wireless Settings both 2.4GHz and 5GHz changed CTS/RTS Threshold to 2307.
    https://community.netgear.com/t5/Orbi/Orbi-RBR40-RBS40-V2-1-4-16-mesh-network-drops-connection-to/m-p/1601598/highlight/true#M35230
    https://community.netgear.com/t5/Orbi/Have-to-keep-rebooting-my-RBR50/m-p/1658603/highlight/false#M44420
    Change the CTR/RTS threshold values for both 2.4 GHz and 5 GHz (2341 and 2345 respectively), changed preamble modes to long preamble, and Set 20/40Mhz Coexistence to 40Mhz only.
    WMM should be always enabled. If Mfr are directing you to disable it to make it work with there products, they should be correcting there products to to work better with it enabled.
    • corradokid's avatar
      corradokid
      Tutor
      Thank you for the reply. Your comment says two different settings to try:
      and
      Which should be tried....one if the other doesn't work?
      • FURRYe38's avatar
        Try the 2307 value first...
        Was meant to try different settings. Sorry or the confusion. These were experiences from users that had Apple issues with Orbi in the past. Was just something to try for other devices as well.
        Seems that some devices and Orbi have problems getting connected. The Mfr of these devcies should test them out with MESH systems so they can see whats going on with newer generation wifi and there products. B mode is getting to be very old and eventually B mode will be dropped from support like mode A was a few years back. B mode is still supported so NG is supporting it in there products. Mfrs should be checking there products as well for compatbility.
        and
