- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
How do you set up an Orbi Satellite via Ethernet?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The app suggests I follow the standard sync process but I wind up with a wireless connection back to the router and am unable to override it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: How do you set up an Orbi Satellite via Ethernet?
Yes, set up the satellite via wireless FIRST. Then after it's connected, connect the ethernet cable between the router and satellite and give it 5 minutes to reconfigure the change.
What FW version are you using?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the quick response! I was out of town and unable to get the info until now.
Router Firmware Version is V2.1.4.10
So I followed your instructions but the Satellite never switched over from wireless to wired when I plugged in the LAN cable from the router.
Now it looks like it does not even see the satellite in my Garage. This is strange becuase my reception is pretty good. 🤔
- Mark as New
- Bookmark
- Subscribe
- Permalink
IS the cable between the router and satelllite good? CAT6 recommended.
Review this:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry, lost track of this. The cable is fine - I used it for my prior WiFi installation.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try a factory reset of the satellite. Remove the current satellite from the router. Reboot the router.
Re-add the satellite via wifi first, should get a top led BLUE after it connects.
Then try plugging in the satellite with the LAN cable, give 5 minutes, then look for the top led to turn BLUE...
See if that linked info helps as well...
- Mark as New
- Bookmark
- Subscribe
- Permalink
I followed this procedure a couple of months ago and it didn't work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. Might try this again after doing a factory reset on the router and set up from scratch. Wired back is working for most...
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
what and where is daisy chain? I've previously sufferred from this exact issue and ended up having to factory reset which has just given me other issues to sort out now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Looks like daisy chain was checked the whole time.
I have some new information that may help. I was troublshooting some Sonos isues with their support and they discovered that some of my devices were assigned a public IP and some private. It looks like the devices that were connected to my Garage Orbi were assigning public IPs. I unplugged the lan cable and let the Orbi fall back to wireless backhaul. Then it assigned private IPs and now all my problems are fixed.
At this point I din't think it's worth trying to get the lan cable to work anymore.
- Mark as New
- Bookmark
- Subscribe
- Permalink
How was the satellite connected when wired? Did you have it connected to the Orbi router? If so, any devices connected to the sattellite should have had a private IP address from the Orbi router.
Wired back haul works only if you have the satellite(s) connected to the Orbi router.
