× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Is the Nighthawk cm2050v modem compatible with Orbi RBR50 router and 3 satellites?
Ricmelendez08
I’m upgrading my current Nighthawk 1100 that I use with the Orbi RBR50 router and 3 satellites (1 the outdoor extender). Could I go up to the Nighthawk CM2050v to use with the existent Orbi mesh mentioned above on Xfinity giga speeds? Is it worth the extra $200 or so? Right now I’m averaging 700 mbps or so, but supposedly I can go to 1200. Any advice? Thanks.
Message 1 of 3
Accepted Solutions
CrimpOn
Guru
Re: Is the Nighthawk cm2050v modem compatible with Orbi RBR50 router and 3 satellites?
The Orbi RBR50 WAN port maxes out at 1GB/s.  The CM1100 modem is already capable of that speed and higher.  There will be no gain from:
  • Purchasing a higher speed modem, or
  • Contracting with Xfinity for more than 1GB/s speed.
Sorry.  The investment to go beyond 1GB is much more than $200.
Message 2 of 3
All Replies
CrimpOn
Guru
Message 2 of 3
Ricmelendez08
Thanks for the quick reply, @CrimpOn! Makes sense to me. Looks like I’ll stick to the old modem, for a couple of more years at least. Don’t want to go replace the whole setup. I appreciate it- have a great day!
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1199 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
