- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Issue keeping a ps4 connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
My setup:
I have my RBR40 router hardwired connected in AP mode to my Verizon Fios Router (with gigabit speed). This RBR40is in a back room in my basement. I also have an RBS20 on my second floor that is also hardwired (to the RBR40) via a hardwire run I have. There is one other sattelite RBW30, on my main floor. In general wifi seems pretty good in most places, however in my son's room his PS4 doesn't keep a stable connection - even when it does work the speeds stink (around 10mbs). The PS4 is located about 20 feet from the RBS20 router, but sometimes seems to connect to the RBR40 in the basement. Even when it does connect to the RBR40 the signal strength doesn't look very strong.
Settings Off:
Enable 20/40 MHz Coexistence
Enable Daisy Chain
Enable fast roaming
Any ideas?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Issue keeping a ps4 connection
Its not recommended to put wfi if routers in the basement. Concrete and steel will inhibit good wifi signal travel and coverage.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
- Mark as New
- Bookmark
- Subscribe
- Permalink
The RBR being inthe basement is the reason the RBS is also hardwired. They are probably about 50 feet apart from each other.
