- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Low speed XBOX series X on LAN port RBK53
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Low speed XBOX series X on LAN port RBK53
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Armor, Smart Parental Controls or Circle, Traffic Meter.
Is IPv6 enabled or disabled on the RBR?
Do other wired devices like PCs get near 900Mpbs when connected behind the RBR?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
FW isn't most current:
https://www.netgear.com/support/product/rbk50#download
Orbi AC3000 Router and AC3000 Satellite
(1733+866+400Mbps)‡
1733 being the wireless backhaul between the RBR and RBS only. 866 is for front haul 5Ghz. 400 is 2.4Ghz.
Game console should be ethernet connected vs wireless.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It would be really helpful to know which Internet Service Provider (ISP) is being used and what speed they have promised to deliver. "Full Speed" is a bit ambiguous.
Some aspects of the problem statement appear inconsistent, such as " On both router/satellites I have the full speed of 1 gig up/down". Yet the XBox reports 180Mbps up. How is the 1 gig speed being measured?
The RBK53 system cannot possibly deliver 1 Gbps over WiFi. i.e. " the RBS, wired to RBR, transmits 1 gig via WIFI" cannot be correct. How is that being measured? The fastest possible Link Rate is 833Mbps, which typically results in actual speed measurement of 400+ Mbps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What speed do you see with same mobile device and Ooklas installable speed test app?
Orbi app measures from the RBR to the ISP modem out to the internet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for posting the screen shot. As @FURRYe38 remarked, the Orbi 'app' reports the results that are conducted on the Orbi router. It does not perform a speed test itself. There is a connection between the router and the device running the app which is used to communicate everything that appears on the app, including the Speed Test results. Actual performance over WiFi can be measured by downloading a speed test app to the smartphone/tablet or by using a web browser on the smartphone/tablet to connect to one of the speed testing web sites, such as Ookla Speed Test (https://www.speedtest.net ) or Google Speed Test (https://fiber.google.com/speedtest/ )
Another unfortunate aspect of the RBK53 product is that Netgear released new firmware for the product in February, 2023, but the Firmware Update feature does not report it or offer to install it. (No one knows why.) I doubt very much that the specific firmware version has any effect on the speed of wired devices. However, one of the common recommendations when discussing electronic products is, "update the software". If you should want to look into this, the newer firmware can be found here: https://kb.netgear.com/000065539/RBR50-RBS50-Firmware-Version-2-7-5-4
Manual firmware updates are a bit tricky. Instructions can be found here:
When testing speed with the XBox, is the same cable used for the connection?
Have you tried using different LAN ports on the Orbi router to perform the speed tests?
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you get interested in manual update, try this process and let us know if it works for the 50 series:
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Gr. Sander from The Netherlands
