- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi CBR 40
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi CBR 40
I set up my new Orbi CBR 40 moden router from my xfinity supplied unit and I am having more issues and wifi outages than with the xfinity unit!! why? I have one satellite as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi CBR 40
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
