MM345's avatar
MM345
Orbi Internet not working after reset?
Help! I recently reseted my orbi and when I tried setting it up it says “no internet connection found”??
  • FURRYe38's avatar
    Whats the Mfr and model# of the ISP modem the routers connected too? Built in router by chance?
    After resetting, did you walk thru the set up wizard?
    Swap ethernet cables between the modem and router?
    • MM345's avatar
      MM345
      Its the orbi model with the 50 in it and it said no internet connection while i was using the wizard.
      • FURRYe38's avatar
        Whats the Mfr and model# of the ISP modem the Orbi router is connected too?
