× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Orbi RBK50 power light flashingred after v1.11.0.8 update
supaderp
Hi,
I tried updating following the instructions from Netgear site : i.e. Update satellite first then router.
After updating the satellite, it was ok. However, while updating the router, the power light just kept flashing red for the next 3 hours.
I checked my default gateway and its currenltly blank. It seems like my default gateway just disappeared.
Model: RBK50.
Advice?
Message 1 of 6
DarrenM
Sr. NETGEAR Moderator
Re: Orbi RBK50 power light flashingred after v1.11.0.8 update
Hello Supaderp
Have you held the reset button for 10 seconds to factory reset the unit? If that does not work the firmware may of went corrupt when updating the unit and I would suggest contacting support.
http://www.netgear.com/support/contact.aspx
DarrenM
Message 2 of 6
EMPTY
Similar thing happened to me. Satellite update was successful but router is just flashing green. Can't reset, tried manual way of updating firmware and still can't connect to it. Will contact support tomorrow.
Message 3 of 6
supaderp
It's bricked. Had to RMA the device.
Message 4 of 6
EMPTY
Just submitted my next business day RMA Smiley Sad
Message 5 of 6
EMPTY
RMA'd the unit.  Recieved the new one and was able to update to beta firmware.  All is good after the update!
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 5803 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
