mzakes
Apr 17, 2022Aspirant
Orbi RBR50/RBS50 no route to host
Model version - RBR50/RBS50
Firmware version 2.7.3.22
I have an issue with my Satellite RBS50. After few hours my network devices connected to the satellite start to report "no internet" or "no route to host". This applies to devices connected wireless or through the wire to the satellite. I can access those devices over local IP address but I can't reach them using public IP address with proper set port forwarding at that moment of time. I have a fix IP address. The backhaul status looks "Good" (5GHz). If I reboot any of those devices then my Satellite seems to realise that something is wrong as it changes colour to magenta and after few minutes everything is back to normal. However, as this happens each few hours its not a sustainable solution to reboot some network device each time.I did a factory reset of the satellite but I am not sure if it really cleaned all the configuration as the problem persists. Any idea how to debug this or what can be the reason behind?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡Try disabling the following and see:
Armor, Circle, Traffic Meter.- mzakesAspirant
Hi,
the ng router is connect to ZTE H288A. It has double NAT, i tried some time ago to configure PPPoE with vlan id but that was unsuccessful so if needed I do port forwarding.
I have a two story house and 30ft was too much. My NGs could not reach each other in a 6m (20ft) distance if they were placed on two different floors. The distance that I have currently is 4m and they still jump from 5Ghz to 2.4Ghz backhaul on occasion.
w.r.t. factory reset - I did that on satellite and reconfigured internet from scratch (without factory reset of NG router) few days back. The problem still persists
Armor, Circle, Traffic Meter were and are disabled.
The setup is very similar to the one from the link shared. I just did not disable the logs from point 7 and have dynamic (not static) channel setup. I will try to adjust that
