GuyCal's avatar
GuyCal
Follower
Oct 25, 2022
Orbi RBR50 slow download speeds with new BT Smart Hub2
Hi,  I have just had BT Full Fibre 900 installed with BT Smart Hub2 router and at router I get 700+ MBps download speed.  Previous ISP was also Full Fibre and with that I achieved good download speed in AP mode on Orbi RBR50 - but now I get 110MBps Upload and sub-30MBps download.  I have updated the Orbi firmware and checked the ethernet connections to the BT Hub, but cannot improve the Orbi download speed.  I also tried disabling the BT router WIFI - also no improvement on Orbi download speed.  Any suggestions gratefully received.
  • plemans's avatar
    Try leaving the bt hub in router mode (disable its wifi) and put the netgear in AP mode.
  • FURRYe38's avatar
    You might ask the ISP if the router hub is needed and if there is a separate ONT, if you can remove the router hub and put the RBR in it's place. Something to ask about.
