faisalkhaliq
Oct 03, 2016Follower
Orbi Satellite Not Working After SSID Change
Hi, I setup my Orbi system and it was working fine. I wanted to change the SSID to my old networks SSID. As I did that my router could no longer see the satellite. I have done multiple reboots. I even reset the main router but as it reconfigured it could not find the sattelite. I tried to reset the satellite but the reset button did not do so. The satellite has a solid white LED ring which does not change. Can anyone please help
Regards
1 Reply
hi
sounds like the sat has disassioated its self or is not assioated
once the orbi router is setup correctly and running
try this
push the sync button on the back of the router for about 10 seconds and release , the lights should come one and pulse magenta
at the same time push the sync button on the sat for 10 seconds and the lights should do the same thing
after a minute or so the both should go from pulse magenta to solid blue then turn off
you should then have connectivity between router and sat
pete
