LarryJoe's avatar
LarryJoe
Preparing for Orbi RBK50 - Some due diligence questions
Hello everyone,
I just ordered the Orbi Triband RBK50.  I have a few questions:
1
I currently have xfinity 1Gb service.  Will this router broadcast greater than 500 bbps wifi speeds?  My current set-up does hit 700-800 mbps over 5ghz when close by.  The specs are confusing for the Orbi as it says best for 500mbps service but also references 3gig broadcasting?  I just want to make sure I bought the right product.
2
During install and set up, will the Orbi put my Xfinity router in bridge mode or do I have to do this manually?  I have heard the Orbi will but not sure.
3
My goal is to disable the xifnity wifi service and name the Orbi network the same thing with the same password.  I assume it broadcasts 2.4 and 5ghz under the same name like the Xifnity router?  I have ALOT of devices, the majorty of them smart home and it would be a pain to reconfigure all to a new network name.
Background - with all the work and school from home, there are days where the drops are unbearable.  It does not seem to be coverage of area related or even bandwidth, but I am out of patience with Comcast and on my second router.  I am thinking a mesh system might serve us better.
Please let me know your thoughts and any other tips you might have.
Thanks
  • plemans's avatar
    LarryJoe wrote:
    Hello everyone,
    1
    I currently have xfinity 1Gb service.  Will this router broadcast greater than 500 bbps wifi speeds?  My current set-up does hit 700-800 mbps over 5ghz when close by.  The specs are confusing for the Orbi as it says best for 500mbps service but also references 3gig broadcasting? The AC3000 is the aggregation of all 3 bands. Not a singular band. And the band that devices connect to for 5ghz is a 866mbps. It uses the 1733mbps connect as the backhaul between satellites. I've maxed out around that 500mbps under optimal conditions.
    2
    During install and set up, will the Orbi put my Xfinity router in bridge mode or do I have to do this manually?  I have heard the Orbi will but not sure.---If you have a xfinty modem/router combo device, you'll need to put it in bridge mode yourself. Of put the orbi in access point mode. Up to you which route you choose.
    3
    My goal is to disable the xifnity wifi service and name the Orbi network the same thing with the same password.  I assume it broadcasts 2.4 and 5ghz under the same name like the Xifnity router? ----yes. I frequently do this because I switch routers a lot. All of them have switched without issues for me.  I have ALOT of devices, the majorty of them smart home and it would be a pain to reconfigure all to a new network name.
    Thanks
    the orbi isn't going to hit the speeds of a flagship single router solution but it will have higher average throughput because of the satellites providing better coverage. Its worked great for me and I'm on xfinity gigabit.
  • FURRYe38's avatar
    LarryJoe wrote:
    Hello everyone,
    1
    Depends on wifi device support and design. Most 5Ghz AC wifi devices max out at around 400-500Mpbs.
    2
    Manually.
    This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
    3
    Yes.
    What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
    • LarryJoe's avatar
      LarryJoe
      Thank you both.  When I said my current xfinity router hits 700-800, this was through speedtest, so since 5ghz devices can't really achieve downloads greater than 500mbps (I think this is what you are saying), I won't worry about it.
      I think the first thing I will do before I open the Orbi box is to put my xfinity router in bridge mode using my ethernet connected iMac.  This is easy enough to do.  Then connect the Orbi and let it do it's thing in terms of set-up.  Make sense?
      The distance between the router and the satelite with be just about 30 feet I think.  Going to put the satelite upstairs and the router will be on the first level in the office.  I have a Peloton in the basement that can be probelmatic.  I may buy another satelite just for this if need be.
      • FURRYe38's avatar
        Yes, just make sure that after you connect the RBR to the isp modem in bridge mode, power off the modem for 30 seconds then back ON. Then walk thru the setup wizard on the RBR with your wired PC.
