yethereiam's avatar
yethereiam
RBK22 provides internet to some devices but not others
I have an RBK 22 system (RBR20 and satellite) and last week it now connects to all devices (except 1 chromecast) but it provides internet only to some devices.
It provides internet to:
S10 (5ghz)
older HP laptop (2.4ghz)
TV (5Ghz)
It doesn't provide internet to:
Pixel 4
XPS
Chromecast
It has a Linksys 6300 connected as a switch (WiFi is OFF).  This is connected to Arlo camera system and Synology.
I can see this computer is connected to the Orbi router according to the Orbi app but it does not provide internet to this computer.  It is consistent for the past week (roughly).
Access control is OFF  (tried ON, no difference)
Daisy chain OFF  (only have 1 satellite anyway)
Mimo OFF
Beamforming OFF
latest firmware.  What can I try now?
  • FURRYe38's avatar
    Temporarily turn OFF the RBS.
    Temporarily disable WPA security on the RBR by logging into the RBRs web page with a wired PC at 192.168.1.1.
    After appling the change, see if those three devices will connect to the SSID name and no password.
    After trying this, re-enabled WPA and TPIK on the RBR and apply the change. Check to see if those 3 devices connect.
    Then try WPA2 and AES...
    • yethereiam's avatar
      yethereiam
      Disabling the security works. Then I re-enabled and it still works.
      Why is this?
      • FURRYe38's avatar
        Possible some of your devices got in bad state with there secure connections and needed to be cleared out. Hard to tell.
        So all is working now with security re-enabled?
        After you re-enabled security, did these devices have you input the PW and then they connected?
        Why is this?
