- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK53 Orbi system or keep my RAX120 and add EAX80?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK53 Orbi system or keep my RAX120 and add EAX80?
The EAX would work similarly to the Orbi system's satellites.
What is the size of your home? Sq Ft? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Would be similar for your RAX system.
House size vs Orbi systems:
https://www.netgear.com/orbi/default.aspx
https://www.netgear.com/orbi/wifi-systems.aspx
https://kb.netgear.com/000038220/What-are-the-hardware-specifications-of-the-available-Orbi-WiFi-Sys...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well most MESH systems are based on having 3 wifi radios, 1 2.4 and 5Ghz and 1 5Ghz wireless backhaul for the main wifi connection between satellites or EX's that supports this. Orbi already has this built in. The 3rd 5Ghz radio is not user configurable or able to connect to with any wifi devices accept for the satellites.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Heres a wifi comparison between the RAX120 and EAX80:
RAX120:
WiFi 6 (802.11ax) Dual Band WiFi (AX6000)
- 2.4GHz AX: 4x4 (Tx/Rx) 1024-QAM
20/40MHz, up to 1.2Gbps
- 5GHz AX: 8x8 (Tx/Rx) 1024-QAM
20/40/80/160MHz, up to 4.8Gbps
EAX80:
— 2.4GHz AX: 4x4 (Tx/Rx) 1024-QAM
— 5GHz AX: 4x4 (Tx/Rx) 1024-QAM
EAX only handles 4.4 MIMO streams on 5Ghz vs the RAX has 8x8 MIMO streams. Mostly handling of bandwidith and device connections here. The connection rates are the same this is good.
By the looks these only have 2 radios. So mostly the EAX would be a extender rather then a MESH system.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ya, Though EX works pretty good for what they do. When I have my XR450 dual band wifi router online as the main router, I connect 2 EX7700s to it. I get great coverage and operation with this configuration.
If you want MESH though, Try a Orbi for your self. IF you need AX, you'll need to try the RBK852:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Kewl. You'll be good. Run the system when it comes in with default firmware or if your interested in getting the latest version, v2.5.1.8 is available and for me and others, seems solid. They fix a bug with device naming problems in this version so it's working now.
Hope the Orbi system works well for you.
Keep in mind:
