- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR/RBS50 FIRMWARE UPDATE general advice please
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi RBR50 v1 here, working fine for 2 years without any issues.
I am a naive user with little IT knowledge
I have been reading alot of firmware update posts and the ensuing complex problems, and would greatly appreciate just some general advice for those of us who are casual users
At the moment, the app states an update is available for my unit. Orbilogin.com shows I currently have V 2.5.1.16 and V 2.5.2.4 is "available" for router and satellite..
So - for those of us naive users out here, is it possible to give some general advice?, ie:
1 - Only let the ORBI upgrade automatically?
2 - Only upgrade when the app shows an update is available, and update directly from the app?
3 - Actively check if if there is an update available at orbilogin.com/advanced/administration/firmware update, and download those updates periodically?
Many thanks,
Jason
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR/RBS50 FIRMWARE UPDATE general advice please
My RBR/RBS50, purchased in November 2020 came with ver 2.5.2.4 on it. It has been stable and doing fine. Using wireless connection (backhaul) between the router base and the satellite.
As for firmware updates, each release has its own quirks. Check here for abnormally high problem reports (there are always some problems with any update) before installing.
In general, if things are working fine, don't update just to get the latest version. I make one exception to that: if an update is fixing some major security problems, especially if the problem is being exploited in the wild.
Unfortunately, Netgear releases quick fixes (which is good) but without extensive quality checks (which is bad). They also don't expound in detail on what they are fixing and how severe the security issues they are fixing.
Summary: There's no good answer to your question.
PS: I am a user. Not a Netgear rep.
Love my Orbi (with this firmware version).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Unless NG pushes FW to your system. You can choose to update your FW to your system or not. If you get notifications on the RBRs web page about a FW udpate, this is only a FW notification. Means it's available to you IF you wanna update. You dont have too..
Some believe that if yoru system IS working fine, then you don't need to udpate. This is also recommended. However at some point NG may push a FW update to your system.
Recommended FW version to use is v16 on 50 series Orbi...
@Jason7 wrote:Hi RBR50 v1 here, working fine for 2 years without any issues.
Many thanks,
Jason
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
I recommend using the RBRs web page to do any FW updated rather than the Orbi app.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks both for your advice.
FURRYe38 - one question please:
When you say "Unless NG pushes FW to your system" -- does that mean that NG automatically updates my units, ie, I do nothing in this case?
Many thanks,
Jason
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Jason7 wrote:When you say "Unless NG pushes FW to your system" -- does that mean that NG automatically updates my units, ie, I do nothing in
Yes. When it first came out, Orbi was like many "Internet of Things" (IoT) devices. It was supposed to "just work" without the user doing anything. There were a number of firmware updates that happened silently in the night. (As far as I am aware, the Nighthawk line of products NEVER did this. It was always up to the user to recognize that new firmware was available and decide to install it.) Alas, some of these updates caused major issues for users and there was a significant "Hue and Cry". Since then, Netgear has floundered in regard to Orbi updates. People post that their Orbi updated firmware without them doing anything to cause it. The Orbi "app" will announce new firmware when the Orbi web interface claims "no new firmware available." Orbi will announce new firmware that is not the "most recent" release. Netgear also emails customers about "security update to firmware". From my viewpoint, customers have good cause to be confused.
As things stand today, "old timers" recommend, "If it ain't broke, don't fix it. Leave it the hell alone." If the Orbi is not working correctly, then a person has to balance the odds that (a) newer firmware will be "better" against, (b) newer firmware will either 'brick' the Orbi or will cause some new problem.
Will Netgear ever "push" new firmware to Orbi without the user doing anything? NO ONE KNOWS.
- Mark as New
- Bookmark
- Subscribe
- Permalink
As a counterpoint to "don't fix what isn't broken", a firmware that has security vulnerabilities, especially if there are exploits in the wild, is broken. Netgear lists the vulnerabilities and fixes (in some cases) on
https://www.netgear.com/about/security/
If one chooses to stay with an older version, then it is a trade-off between stability and security. But it should be an informed decision. Like I said in my earlier post, Netgear may choose expediency over robust testing when releasing such hot-fixes.
Having been so preachy, I myself have not updated to the latest version.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, if your Orbi appears to have a fw update applied, you should be able to continue to use the system normally. Some have posted seeing issues after NG pushes FW. Some have not. One thing to try if you notice anything, Power OFF the RBS and RBR for 30 seconds then back on. Sometimes this resolves any odd problem seen after a auto FW update.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@alokeprasad wrote:As a counterpoint to "don't fix what isn't broken", a firmware that has security vulnerabilities, especially if there are exploits in the wild, is broken. Netgear lists the vulnerabilities and fixes (in some cases) on
That's a matter of opinion.
To keep things in perspective, NG used to push ALL firmware updates. You had no choice. Then users whined and cryed and wanted more choice and freedom. Just thought you'd lke to know.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My theory, FWIW, is that when Netgear is confidant about the quality and need for the update, they will put those up on the servers that feed the "check for update" feature on their device web interface.
Mine still is happy with 2.5.2.4. I'm loath to recommend any newer version, except to grizzled veterans who are aware of the risks in doing so.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@alokeprasad wrote:My theory, FWIW, is that when Netgear is confidant about the quality and need for the update, they will put those up on the servers that feed the "check for update" feature on their device web interface.
My sentiments exactly. Be careful how you state your position in here. Some don't take kind to such views. Personal attacks run rampant. My skin has thicken while existing here.
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry if this has been answered definitively but I want to make sure I'm headed in the right direction. I've had my ORBI since October 2019 and am happy with it overall.
It's on Firmware Version V1.4.0.18
Once in a while (such as today) I get a notice about a firmware update for security or other reasons. It tells me to go to router settings and scroll down to check for firmware update except mine never has anything that says check for firmware update or to tell me that the firmware has been updated. The only option when I scroll down is "reboot."
Your recommendations are welcome. Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
SInce your Orbi is on a old version of FW, you'll need to manually downloade a couple of versions of FW to bring your system into being able to see newer FW updates on the RBRs web page. v2.0.0.74 and v2.2.1.212 are steping versions of FW.
v1 FW versions won't see any newer FW updates from NG update servers.
@Hitchfan wrote:Sorry if this has been answered definitively but I want to make sure I'm headed in the right direction. I've had my ORBI since October 2019 and am happy with it overall.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The real question is why doesn't netgear update this automatically since it's so old. Another flaw with the product?
