× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
RBR10 Mesh WLAN Geräte kommnizieren nicht untereinander
JoKo_BN
Hallo Allerseits,
ich habe ein Meshsystem mit RBR10 und zwei Satelliten installiert. Das System lässt keine Kommunikation der WLAN Geräte untereinander zu. Es geht z.B. kein Streaming vom Handy in den TV über airplay etc.
hat jemand ne Idee wie ich das behebe? ich finde in der App keine Option dazu
VG
Message 1 of 5
Guru
Re: RBR10 Mesh WLAN Geräte kommnizieren nicht untereinander
what modem/gateway is the rbr10 connected to?
Message 2 of 5
JoKo_BN
Hi
It’s connected to the Internet via a FRITZ!Box 7560 (Ethernet cable from FRITZ!box to Orbi)
Regards
Joerg
Message 3 of 5
Guru
The fritz box has its own integrated router and can cause a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-M...
Message 4 of 5
CrimpOn
Guru
There is no option in the app. Connection between WiFi devices should be automatic.
This can be demonstrated in several ways. For example, use a networking app on the phone to 'ping' other WiFi devices.
I have several networking apps for Android, but have no experience with iPhone.
Many devices respond to ping, such as Sonos speakers, Nest Mini speaker, etc.
My guess is there is a setup step missing in the Apple Airplay setup. I would focus there.
Tut mir leid, ich habe kein Deutsch (Goodle Translate)
In der App gibt es keine Option. Die Verbindung zwischen WLAN-Geräten sollte automatisch erfolgen.
Dies kann auf verschiedene Weise nachgewiesen werden. Verwenden Sie beispielsweise eine Netzwerk-App auf dem Telefon, um andere WLAN-Geräte anzupingen.
Ich habe mehrere Netzwerk-Apps für Android, aber keine Erfahrung mit dem iPhone.
Viele Geräte reagieren auf Ping, z. B. Sonos-Lautsprecher, Nest Mini-Lautsprecher usw.
Ich vermute, dass im Apple Airplay-Setup ein Einrichtungsschritt fehlt. Ich würde mich darauf konzentrieren.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 894 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
