× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
RE-SET UP ORBI
FROMTHESWAMPWOO
RE-SET UP ORBI
I HAVE CHANGED WIFI  SINCE I HAD MY ORBI SET UP ORIGINALY.  DO I HAVE TO CHANGE ANYTHING.....LIKE  THE WIFI POASS WORD ??  IF SO HOW  DO I DO THIS ?  I DID NOT SET UP THE ORBI MYSELF  SO I AM NOT SURE WHAT WAS DONE OR WHAT I NEED.
THANKING ALL INADVANCE,
Message 1 of 5
Guru
Re: RE-SET UP ORBI
log into the RBRs web page with a PC and web browser at orbilogin.com or 192.168.1.1.
You can change the SSID and PW to your liking under the Basic tab/Wireless settings here.
Message 2 of 5
CrimpOn
Guru
Re: RE-SET UP ORBI
This doesn't give us much to work with.  "Changed WiFi" could mean a lot of different things.
Are you able to access the Orbi WiFi by selecting the Orbi from a list of nearby WiFi networks and entering the password?
Are you seeking to make changes to the administrative interface, but do not know the administrative password?
A little more description of the problem would be helpful.
Message 3 of 5
FROMTHESWAMPWOO
Re: RE-SET UP ORBI
OK MY WIFI SERVICE SENT ME A NEW WIFI ROUTER.  CAN I JUST PLUG ORBI IN  AND BE GOOD  TO GO ?  DO I HAVE TO PUT IN THE NEW ROUTER ( PASS WORD-  THE BIG LONG ONE ON THE BACK OF ROUTER )  I AM SORRY I AM VERY IGNORANT ABOUT THIS  STUFF BUT I DID NOT SET UP THE ORBI   ORIGINALY  SO I DO NOT HAVE A CLUE.  I DID HAVE  TO CHANGE THE INTERNET SERVICE NUMBER ON MY I PHONE DOES  THAT HELP? WHAT I MEAN IS BEFOR IT WAS FRONTIER ???????   AND NOW I IT IS FRONTIER  xxxxxx.  IF I NEED  TO DO THE SAME THING  FOR MY ORBI HOW WOULD I GO ABOUT DOIN THAT?
THANKING YOU AGAIN,
ANN
Message 4 of 5
Guru
Re: RE-SET UP ORBI
If your service send you another router, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Please stop using caps. No need to yell.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 962 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
