- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Ring led on RBR50
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ring led on RBR50
Hi,
I have a RBR50 and 3 satellites. I have a hardware firewall in front of the RBR50 and the RBR50 in AP modus.
The network cable is not in the routerport, but in one of the switch ports. All is working fine, wired, mesh and wifi, but the ring led is constently solid magenta/red. How can I turn the ring led off?
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ring led on RBR50
Connect the RBR to the host router using it's WAN port.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks, but unfortunally the satellites won't connect anymore, even after a reset. I have resetted the satellites as well, this will not bring them back up again.
Put the cable back into the switch and connected the satellites again and that's working fine.
I will get some tape and put it over the ring led 😞
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello WS-010,
Welcome to the NETGEAR Community!
I understand that you have a red light showing on your RBR50. To resolve this issue please connect the ethernet cable from your switch to the WAN port on your RBR50. It is the port in yellow with the text "internet". After you connect your RBR50 to the switch verify that you are able to access the internet from a device connected to your RBR50. Then from your Orbi app navigate to Menus ( on the top-left) > ADD SATELLITE. Then connect your additional satellites to your RBR50.
Best,
Kevin
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks, I know that I can solve the red ring led issue with the WAN port, but 2 of the 3 satellites are unable to connect. They are all on the same hardware etc.
So restored my old setup and that's working again and I leave it to this. Thanks for the help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I do not have 2 connection from the wall outlet, so I am unable to try this. However, thanks for the help
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
No, I do not, but next to that, there is no room on the shelf for additional hardware. Thanks, but I keep it this way, it is working 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please note that there are very small switches for two cables that you might consider.
Anyways, the magenta color is nit that bad after all. 😊😊
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
