× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Some error occurred while enabling/disabling remote management
Turky
When selecting to enable Remote Management on the orbi app, a message comes up saying “Some error occurred while enabling/disabling remote management”.
Anyone have any ideas?
Orbi WiFi System (RBK13) AC1200
FW 2.3.6.18
IOS
June 2020
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 5
CrimpOn
Guru
Re: Some error occurred while enabling/disabling remote management
The attached screen shot is about firmware update, not Remote Management.  Can you please post a picture of the error message?
Message 2 of 5
Turky
Sure
Attached the error picture
Message 3 of 5
Turky
Message 4 of 5
CrimpOn
Guru
Geez, "some error" is not particularly helpful.  This appears not to be the first time someone has run across this.  A Google search for that phrase turned up a number of hits, not all of them on the Netgear Orbi.  This forum post seems to indicate a solution:
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-remote-management-not-working/m-p/1649177#
I am not entirely certain which "reset" this use did (there are two).  Just pressing a sharp object (such as an unbeent paperclip) into the tiny "Reset" hole for 1 second will "reset" the Orbi and restart it.  A more drastic step is to perform a "Factory Reset":
https://www.youtube.com/watch?v=cMw4ePACgc4 This requires you to set it up again, which can be tedious.
There is a chance that people who pariticipate in the community forum specifically for the Orbi "app" may have more insight.
You might want to post there.
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 945 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
