Orbi WiFi 7 RBE973
Reply
Synology NAS Quickconnect with Orbi
Jeroen07
Follower
Hello,
I have setup my Netgear ORBI system, which works great regarding WIFI coverage.
One problem though, I used to connect externally to my NAS with the quickconnect.to functionality: https://blog.synology.com/?p=2283
This doesn't work anymore. I guess Orbi is blocking external connections? Any idea how I can fix this? Or do I need to adjust my settings on my NAS?
Message 1 of 3
eljarviso
Luminary
Re: Synology NAS Quickconnect with Orbi
I have the same problem. Ended up manually opening DSM ports and using Synology.me ddns
Message 2 of 3
bioits
I have the RBK50 with Synonlogy ds418j setup and it works fine. I used as AP mode instead of router as I have FIOS router.
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2516 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
