nywolf's avatar
nywolf
Video buffering and slow internet
Same issue since firmware upgrade.  Streaming TV shows buffer and video calls freeze.
  • FURRYe38's avatar
    Not much to go on.
    What NG product are you referring too?
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    There's a support site with access to manuals, firmware, install guides, etc.
    Go to https://www.netgear.com/support/
    Type in your model number and from there it'll take you to the above.
    Its a great resource to start with.
  • Orbi RBR50
    Firmware:  V2.7.4.24  (latest version)
    Internet Provider:  Spectrum
    Modem:  Technicolor ET2251
    Issue only started happened when I upgraded to latest version.   Will go back to previous version of Firmware unless
    there is a fix for the current one.
    • CrimpOn's avatar
      CrimpOn
      Seems pretty clear to me: update firmware, issues arise.  If manually loading the previous firmware makes the issues go away, that's all you can do at this time.  (Please check your private messages in a few minutes.)
