JimCoho's avatar
JimCoho
adding beyond 3 satellites for orbi ac2200 RBK44- possibly via daisy chain?
Hi, I have an old home with stucco walls and some deadspotes despite my 3 satellites and the router stuck in the basement.  I am tired moving my orbi satellites around to accomodate reception.  I read there is a limit of 3 satellites spoked on this system.(sorry I am not technical).  Can you daisy chain additional ones onto these 3 to add another satellite or 2?  also which satellites would be compatible with my orbi ac2200 RBK44?   Thanks,  Jim
  • FURRYe38's avatar
    It's possible. Other have posted having 6 RBS connected though didn't mention if Daisy Chain was in the configuration.
    • JimCoho's avatar
      JimCoho
      Ok thanks. I'll see if any others respond about the daisy chain idea beyond the 3 satellites.  are there certain satellites compatible with my older system(2018) that you know about?  Thanks
      • FURRYe38's avatar
        RBS20, 30, 40, 50, RBS50Y outdoor, and RBW30s are all compatible.
