deereman75's avatar
deereman75
orbi router is staying magenta other two satelittes are green
rbk23 on the app shows the router is magenta and the other 2 satelites are green  i have wifi and internet  also it will not hook up to play station 4 for some reason
  • it started working all of a sudden and was able to connect to playstion  didnt really do anything
  • FURRYe38's avatar
    • deereman75's avatar
      deereman75
      firmware is V2.3.5.30 internet is bridge from another modem
      • FURRYe38's avatar
        What happens if you turn OFF the modem and RBR for 1 minute, then power ON the modem first and let it sync then power ON the RBR.
        Be sure to check the modems ISP service signal as well. If the RBR is connected to a bridged modem and the signal fails for any reason, the RBR may reflect this with the top ring appearing as PINK.
