philipmarker
Apr 05, 2022Aspirant
RBK753 AX4200 - Router placement & daisy chain
Does this model support daisy chain ? When trying to find activate/deactivate box under admin log in (advanced wifi-setting), it does not pop up ?.
Have problem with connection to one of the satelittes and moving the router more cental in the house is quite a hazzle with cabling. So was looking to see if an extra satelitte and using daisy chain could be an alternative solution. The house is quite "long"
It does support daisy chaining but it isn't user changeable. Its auto-negotiated within the orbi itself whether daisy chain or star topology will work better.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
