- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR750 dropping internet connection over ethernet
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: RBR750 dropping internet connection over ethernet
RBK752 bundle: 1 RBR750, 1 RBS750
Network Connectivity is as follows:
Frontier Fiber ONT -> RBR750 via ethernet from ONT (RBR750 is setup in Router mode, VLAN/Bridge mode disabled, traffic monitor disabled, ipv6 disabled) -> RBS750 connected to RBR750 via wireless backhaul.
5 wireless devices connected, 1 wired device connected to RBR750 via ethernet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
IF the RBR is showing Pink front LED, this means the RBR is loosing the connect to the ONT or the ONT is loosing connection to the ISP services.
I'd make sure the ISP service line up to the ONT is to spec.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure to power OFF the modem/ONT for 1 minute them back ON along with the RBR.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router RAXE50 and R7960P(v.88) Router Mode and RBK752(v.2) AP mode | Switches NG GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I recommend you make contact wtih NG support and let them know what your seeing. Let them know that you tested a different router and that work and Orbi doesn't.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Have you tried this?
@AggedwNG wrote:
Unfortunately not.. Still waiting on a response from Netgear support. Issue is still present. There is one thing I have noticed once or twice when duplicating the issue. Close to the same time the network drops when I'm wired into the router and trying to download, the green power led light on the back of the router will sometimes turn red for a split second or two before the led on the front turns magenta. I've been reading in different places where I'm seeing complaints about this and some are mentioning a kernel panic. It doesn't seem to do this everytime but the front router led always turns magenta and crashes the entire network without fail and is only recoverable with a hard power cycle. Not sure what they did with this firmware (other than intentionally remove our ability to manually downgrade) but I'm starting to suspect this could be bricking some devices after time. They need to address this.. Hopefully they're not taking an errant approach and allowing a tolerable percentage of collateral damage with these changes..
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Good Luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@FURRYe38 @AggedwNG Have you figured this out? I'm having the same issue, but it had been happening when I try to download updates through Adobe Creative Cloud. Fast forward to today, I tried to install Halo Infinite through Steam and the download crashed my router again. Orbi mesh system is the RBK753S.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Something to review here as some others are seeing this crash on the RBR when downloading large size games:
Contact NG support and let them know what your seeing.
