- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR750 firmware 4.6.9.11_2.3.5 cannot change admin password via web UI
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just discovered on my RBR750 running firmware V4.6.9.11_2.3.5, I cannot change the admin password via the web UI. I can fill in the fields, clicking Apply does nothing.
Also cannot change the password recovery questions with idential symptoms.
I discovered this after updating to the latest iPhone Orbi app, which then failed login, insisted on FaceID including trying "Forgot Password", and a number of items no longer displaying properly (separate thread created for that).
Make sure you've secured all of your login info for your Orbi!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR750 firmware 4.6.9.11_2.3.5 cannot change admin password via web UI
Hi @JoesOtherCat ,
For "I cannot change the admin password via the web UI" =>
What's browse do you use ?
What's laptop(Window or Mac) do you use ?
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Windows 10. Tried using FireFox (latest version) and Chrome (latest version).
On iPad (iOS 15.7), FireFox (latest version), Safari (latest version).
Filled in old, new, new password and [Apply] button does not change. Clicking on [Apply] it appears to depress but nothing happens.
Same when trying to add/edit a password recovery question, regardless whether any passwords are filled in the old and new fields or left blank.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does MS Edge do the same thing on Windows?
After FW was updated, did you just reboot and continue or did you perform a factory reset and setup from scratch?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just tried on mine. I thought it didn't take but gave it a few more seconds then the log in pop up appeared in MS Edge for me. Logged in with the new PW. I then opened Firefox and use that browser to change the PW back to what I had before. Got same response and PW was changed back. Windows 10x64 on a wired connection the RBR.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hmm, that’s interesting!
Answer to your previous post, I launched the firmware update via the iOS Orbi app, just letting it run through its routine. I have never done a factory reset and restore.
I’ll have to try again, with Edge and then again with FireFox. I do have extensions added to FireFox though none I can attribute to causing this issue. And not nearly as many as with Chrome (and of course the extensions are different).
Thinking about it more deeply, I do have 1Password installed (and running as a browser extension). Although that popped to auto-fill the (old) password, I copy/pasted and typed them in to bypass 1Password, to no effect.
Thanks for much for the feedback! I’ll be sure to update this thread with my findings . . .
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any progress on this?
