- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR850/RBS850 WiFi slow on a 1GIG fiber (getting 90Mbs up/down)
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have att 1 gig fiber ( 1 RBR router ) - (4 satellites) 6500 SQ ft house
satellites are 25-30 ft apart on second floor < Router ( which acts as bridge) also on second floor ( hard wired to ATT)
used to get 350mbs , then has issues with drops so i disconnected one of the satellites. Still gets drops, but not that often, challenge is over the last month WiFi speed has dropped to less than 100mbps down and up causing issues on all connected devices
v. 4.6.3.16 on router and satellite
Any ides thoughts on how to fix would be appreciated
Rima
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR850/RBS850 WiFi slow on a 1GIG fiber (getting 90Mbs up/down)
Try starting with the diagnostic steps outlined in the community FAQ: https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/Community-FAQ-My-Orbi-speeds-are-slo.... The results will isolate where your speed drop is occurring, then we can focus improvement steps for that point.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks i did all that .
hardwired into att arris - 750 download, 930 upload
hardwired into RBR Router - 94 ( upload 'download)
reconfigured everything so that att Arris is set up a a bridge , RBR set up as router with pass through. Issue is hardwired right out of RBR speed is extremely low
- Mark as New
- Bookmark
- Subscribe
- Permalink
@rimasidd wrote:Thanks i did all that .
Thanks, now we know to look at the RBR speed drop and can factor out wireless for now. So you have bridged your modem and wired download speed is 94 Mbps vs. 750 Mbps when removing the RBR? That is surprising.
Do you recall what default settings you changed on your Orbi? Make sure you have not enabled Armor, Circle, Speed Test, Access Controls and Traffic Meter.
As a last resort, how do you feel about factory reseting the Orbi and then seeing if the speeds recover?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does the 850 router have an Advanced Tab home page similar to the older Orbi routers:
If so, what does this option indicate for the router WAN port?
(The reason I ask is that 90mb is a 'suspicious' number, being just short of 100mb.)
If the Orbi believes that it is connected to the ISP device at 100/Full, then the maximum speed will be just under 100mb.
This is probably not the case, but requires less effort to check than a Factory Reset.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also be sure your using good quality LAN cable between the ISP modem/ONT, RBR and all wired devices.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It does - the router wan port is 100M/Full
- Mark as New
- Bookmark
- Subscribe
- Permalink
When the Orbi "knows" that the port maxes out at 100mb/Full Duplex, then it will not receive faster than 100mb.
How this happened when nothing has changed is one of those mysteries of life. I would try a different ethernet cable and also take a really good look at the tiny gold wires inside the ethernet jack of the ISP device and the Orbi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi has 4 ports ( i tried each one) the cable is fine as when I connect to ISP modem it shows 850-/900 upload /download
is there a way to configure the WAN port? Or is it automatic?
- Mark as New
- Bookmark
- Subscribe
- Permalink
IF the WAN port is only showing 100Mpbs, then there can only be a few things, Bad cable between the ISP Modem and RBR. ISP Modems WAN ports is faulty or not supporting of 100Mpbs. Or RBR WAN port is faulty.
Check support of the WAN Port on the modem.
Check LAN Cables. Swap lan cables between the modem and router.
There is not speed settings on the WAN and LAN ports, there all automatic detection of speed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Maybe it is the ethernet jack on the Orbi? (At my age, it takes a special pair of reading glasses to be able to focus on those little wires.)
No. There is no way to 'configure' the WAN port. That is entirely automatic.
https://en.wikipedia.org/wiki/Autonegotiation
It is really frustrating that Netgear elected to omit the tiny LEDs from the Orbi ethernet jacks that indicate connection speed and traffic. (True, most customers would rather not have LEDs blinking in the bedroom, but that's why black electrical tape was invented.)
If you happen to have a (really dumb) gigabit switch on hand that does have the LEDs, it might be useful to connect it between the ISP device and the Orbi WAN port. Some customers are fortunate to have access to the inner workings of the ISP device and might be able to see what the ISP "thinks" about the Orbi link.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Will update tomorrow
- Mark as New
- Bookmark
- Subscribe
- Permalink
ok Mental note - Do not reset Orbi ( it has taken me all day yesterday to get it running and still only 2 satellites connect, the other 2 are still MIA)
I also changes ports and used different cable but the throughput is still 94 MB from the router.
so now:
1. any ideas on how to factory reset the router and get a clean pairing of the 4 satellites?
lets get this solved first then I will tackle the speed hthroughput
Thanks
@rimasidd wrote:
First of all thanks to all of you responding. I will try out different cables, and see if I can swap out the ISP device.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
I would turn OFF the RBS for now as it seems the main issue is at the RBR.
After you reset, power OFF the ISP modem/ONT and RBR for 1 minute. Then back ON with the modem and RBR. Walk thru the RBRs setup wizard with a wired PC and web browser. Once completed, check the connection status page. IF you still see 100Mb on the WAN port, then there is something wrong with the RBR.
What is the model# of the Internet Service Providers modem/ONT the NG router is connected too?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks will try it out
ISP device is a ARRIS BGW210-700
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let us know what it shows.
