- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Found Fix To IoT Disconnect Issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi All,
I've been experiencing daily disconnections on the Orbi 970 IoT network while using the "2.4 GHz only" mode. However, after switching to the "2.4 GHz and 5 GHz" mode, these disconnections have ceased. This issue persisted across all firmware versions I've used, including the current one (V9.10.4.1). I suggest someone report this to Netgear as a potential bug for investigation. I just wanted to provide this update in case it helps someone else.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Found Fix To IoT Disconnect Issues
Correct. My connection has been stable for a week with no disconnects, whereas previously I would experience them daily, particularly with devices like Nest, 2.4GHz-only Ring cameras, and other 2.4GHz-only devices. This improvement has been a significant relief.
- Mark as New
- Bookmark
- Subscribe
- Permalink
How many devices did you have all contacted at one time while using only the 2.4Ghz radio for the IOT network?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are any of these 44 devices 5Ghz supporting?
Possible that having that many on the 2.4Ghz could be causing it to over load and destabilize. Seems that since you enabled 5Ghz that some of these off loaded to 5Ghz and whats left on 2.4Ghz is stabilized.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I agree with your theory. Currently, 21 of the 44 devices are connected to the 5GHz IoT network. Surprisingly, I've found that many devices, initially connected to the 2.4GHz band, also support 5GHz. This includes the latest models of Alexa devices and Nest thermostats
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please help me understand something. Do I even need the IoT network?
Does the ferrari network only do 5Ghz and 6Ghz? so the IoT (i3 network) is needed for 2.4ghz devices.
Also do you think there is a speed difference between ferrari and i3 5Ghz networks if the device does not support 6GHZ? Like should I move my 2.4Ghz/5Ghz capable devices over to Ferrari to get a speed increase...
- Mark as New
- Bookmark
- Subscribe
- Permalink
All three frequencies are supported on the main WLAN network.
The IoT network is there for users to use for IoT devices and specifically for 2.4Ghz devices that historically had problems connecting to Older Orbi systems that didn't have this feature.
Kinda need to test things out as you see fit and see what works best for you. I presume if you have lots of just IoT devices that don't need fast speed or performance, put them on the IoT network and save the main WLAN for devices that need good speed and performances.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I find and have found that just leaving all devices on the main, is the best option, so easy to fix and swap devices on the main than swap between and play with both is just nonsense to me. If the router can't handle it then its time to swap routers.
On another note not related to this- the firmwares Netgear has been releasing for this wifi 7 router , has been great compared to other Netgear routers I have had. Meaning not causing other problems, just fixing things, NICE.
I have over 60 devices , No IoT , all on the main and no problems to date.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
