× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
IPv6 setup help RBE972s
Jtcooper87
Tutor
I just bought the RBE972s and I am having issues setting up IPv6. My service provider is Kinetic by Windtream. I know for a fact that they have IPv6 because it works with the rented router that they provided.
Message 1 of 7
Jtcooper87
Tutor
Re: IPv6 setup help RBE972s
As info: I applied the "auto-detect" feature and after reboot came back as a 6to4 Tunnel, but doesn't seem to be working.
Message 2 of 7
Guru
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Do you have the RBR connected behind another router?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
If you put the RBR in AP mode behind the ISP router, does IPv6 work then?
NG is aware of some issues with IPv6.
Message 3 of 7
Jtcooper87
Tutor
1.So the RBE972s is running the latest firmware available: 9.10.4.1_1.1.17.
2.I am not using the Orbi as a bridge currently. The Orbi is connected directly into the wall port using the supplied cable that came with the RBE972S.
3.I was able to have Ipv6 at my house next door using a Netgear Nighthawk AX6 router (no modem/same ISP).
Message 4 of 7
Guru
What is not working specifically with IPv6?
Have you been to https://ipv6-test.com to check the state of the protocol?
Message 5 of 7
Jtcooper87
Tutor
1. -My Xbox Series X does not recognize the connection as IPv6 at all where it did before switching routers.
-Given that my ISP, provides native IPv6 (at least I was told by my ISP), I would prefer not using the 6to4 Tunnel, since it is a dumbed down version of IPv6.
2.I went to a similar site, but I have attached the results from the above mentioned website.
Message 6 of 7
Guru
And if you disable IPv6 on the RBR does xbox work normally?
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 714 views
  • 4 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
