Gsosa
Oct 20, 2023Aspirant
Orbi 970 and 2 Satellites - I just got the system and also have fios.
I just got the system and also have fios. I am having the same issue. Reboots between 30~60 minutes. Orbi connected to ONT directly. I fear i may have to return the system based on this thread. Support has not been able to figure it out today.
- JHMBStar
If you want to point Netgear support at my ticket my case number is Case #: 47732804
I dont think that it will help you because my issue was not resolved, but it may provide some additional context to your support person.
For what it's worth I set my older Orbi RBK853 mesh system back up last night and it is working great. I dont know what about Verizon Fios would be a problem for the 971 and not the 851, but maybe Netgear can shine some light on it.Good luck.
- GsosaAspirantI just got the system and also have fios. I am having the same issue. Reboots between 30~60 minutes. Orbi connected to ONT directly. I fear i may have to return the system based on this thread. Support has not been able to figure it out today.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.Does the front LED turn PINK when this happens?
Has a power off for 1 minute then back ON with the ISP modem and router been performed?
Turn off and unplug modem.
Turn on computers and rest of network.Is Armor or Smart Parental Controls enabled?
