Darcy118
Sep 27, 2024Aspirant
Orbi RBE971 dynamic DNS support
| Hardware Version | RBE971 |
| Firmware Version | V9.12.3.3_1.2.20 |
| GUI Language Version | V4.0.0.21_2.1.30.3 |
| Protection Engine Version | 2.2.184.2 |
| Operation Mode | Router |
I am a little surprised that my new Orbi does not appear to support DynDNS.org . I am certain that previous Netgear routers I have owned supported this.
Am I mistaken? The drop-down for the setup mentions only Netgear, No-IP.com, and Dyn.com ...
That URL isn't valid or has been taking over by something else.
- Darcy118Aspirant
Dyndns.org redirects to dyn.com, yes. But if I select dyn.com in the Orbi dynamic DNS drop downs, my credentials do not seem to be accepted. If I fill in the form and click Apply, then click Show Status, the Orbi responds with an empty web page having this message:
Authentication failed. User name or password is not correct.
I have carefully cut and pasted my account and password into the Orbi setup form three times now, and feel it is unlikely that I have made a user error.
