BG33's avatar
BG33
Tutor
Oct 26, 2021
CBK752 Modem is very unstable, can i use just as a router
I have the CBK752 with one sattelite, when it is working it is great. However, it losses its internet connection almost daily, only way to get it back on is to unplug and plug back in. So, is there a fix or can i buy a different modem and use this orbi just as a router. Never had this problem before switching to this router/modem combo.
  • I am having the same issue, why is everyone so quiet about this? Is there no support left in this world. Why is netgear not standing behind their products. This is insane to me....
  • FURRYe38's avatar
    Please post a copy and paste of the modems connection status page.
    Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
    Be sure there are no coax cable line splitters in the between the modem and ISP service box.
    Be sure your using good quality RG6 coax cable up to the modem.
    Be sure to power OFF the modem for 1 minute then back ON.
    https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
    What channels are you using? Auto? Try setting manual channel 11 on 2.4Ghz and  48 channel on 5Ghz.
    • BG33's avatar
      BG33
      Tutor
      Appreciate the advice. Not sure about a modem connection status page but will check. I also called the help line within 90 days and they had me change the channels from auto, worked for a few days then the daily instability came back.
      Since my old modem did not have this issue, can I just set this one to only a router somehow and connect a new modem. Hard to have internet go out when on video calls with clients. Again works perfect and fast, but need to reboot almost everyday. Thanks!
      • FURRYe38's avatar
        Would need to trouble shoot a bit more to see whats going on.
        If you can give feed back on the questions presented.
        Also,
        https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
        What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
        Try disabling AX mode on 2.4Ghz on the CBR.
        No the CBR can't work as a router only.
    • Triggs21's avatar
      Triggs21
      Star
      Got rid of orbi and never looked back. Having no probs now.
      • rmarcare's avatar
        rmarcare
        Apprentice
        Different modem/router combo? Did netgear refund you?
  • FURRYe38's avatar
    Any progress on this?
    FYI:
    https://community.netgear.com/t5/Orbi-with-Built-in-Cable-Modem/CBK-752-Firmware-updates-CBR750-V4-6-3-6-RBS750-V4-6-3-7-dropped/m-p/2177825/highlight/true#M2783
    • rmarcare's avatar
      rmarcare
      Apprentice
      does reverting back to FW v3 actually fix the intermittent wifi issues?
      • atejwani's avatar
        atejwani
        Apprentice
        Hi RMACare,
        I feel your pain. I have the same CBK752 (CBR750 + 1 RBS750). I finally have gotten back to somewhat of the stability and performance, that I had prior to the V4 firmware upgrade pushed to us Aug/Sep 2021. Thanks to a fellow community user who shared the link to beta RBS firmware (V4.6.6.11).
        Direct message me and, if need be, we can jump on a Zoom call. I'm in PST timezone. I can share my experience, provide what has worked for me, and hopeully get you to a better spot.
        My head is still spinning - great hardware, horrible Netgear firmware update pushed. And the Netgear support process, or the lack of it. Additionally this quasi semi official Netgear community, where a SuperUser, although trying to be helpful, has been sending me down rabbit holes! I have questioned Netgear's overall customer service channels (Community, Telephone Support, Web Chat, etc.)
        I bought CBK752 (CBR750 + 1 RBS750) directly from Netgear in December 2020. Things were awesome till August 2021, when V4 upgrades were pushed to our modem, router and satelite, and since then I have performance dergadation and stability issues. I have several posts ( https://community.netgear.com/t5/user/viewprofilepage/user-id/898695 ) , also opened up about half a dozen Netgear Support cases. No resolutions, and now I am past the 1 year support.
        Thanks,
        Al
