steveberry10's avatar
May 16, 2020
Orbi CBR40 password reset endless loop
I'm trying to reset the admin password on my Orbi cable modem/router and I'm stuck in the old endless loop: answer questions, choose new password, answer questions again, password is invalid, rinse & repeat.
I've read that this is a bug so has there been an upgrade to fix it yet?  Otherwise is there a way I can do this without doing a factory reset?  I'm really not wanting to go down that path.
I have an Orbi CBR40, connecting from MacOS 10.15.4 (Catalina) using Safari 13.1.  Any help would be greatly appreciated.  Thanks.
  • FURRYe38's avatar
    Factory reset the CBR40 and setup from scratch. Be sure to walk thru the setup wizard and write down all important information for safe keeping.
  • Did you get a splve for this. I'm havinng the same issue. Tried on multiple browsers and devices.
    • FURRYe38's avatar
      • d700's avatar
        d700
        Apprentice
        Same is happening on my Orbi RBR750.
        Joke is on me, I swore off Netgear after buggy software and aggravation on the last 2 NightHawks I bought. My son recommended this new company, Orbi.
        It worked great when I set it up the first time but I almost took it back when I learned it was a Netgear company,
        Once I started having problems like this I wish I would have.
        I am about to do my 2nd factory reset in 6 months.
        I absolutely hate Netgear and will not recommend either Netgear or Orbi to anyone. Not to mention these forums are a joke, blind leading the blind, noone from Netgear monitors, offers solutions.
        Netgear you are just horrible
