- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Absurdly Slow Speeds from Orbi RBR50
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have had the Orbi RBR50 and satellite for over a year now with no problems. Recently, download speeds have gone from 40 mb/s to 1 or 2 mb/s. This happens for about an hour, and then returns to normal 40 mb/s for about 10 minutes. I have recently updated to the newest firmware, and have tried turning on and off multiple different settings within the Orbi settings. This problem is not with the ISP, as speeds coming straight from the modem/router are normal. Any recommendations? Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Absurdly Slow Speeds from Orbi RBR50
Is the Orbi system operating in Router or AP mode?
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
