Orbi WiFi 7 RBE973
Reply
Can I have 3 VLANs in ORBI RBR50
ShadowHead
Tutor
Gents / Ladies:
Cross linking this post from PFSense forum. I am curious if anyone has succeeded in getting 3 VLANS working on RBR50 in Router Mode. See attached network diagram. I seem to be able to get the default VLAN ( and wireless devices) under one network, and VLAN3 working in port 3 with some appropriate IP addresses 192.168.3.x.
However, PORT 2 does not seem to route to VLAN2 and provision dhcp addresses in the 192.168.2.x range.
This is the post from PFSense on the isse at hand,
https://forum.netgate.com/topic/153192/dhcpnak-or-offer-in-vlans/2
Can ORBI work in this way ?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 5
Guru
Re: Can I have 3 VLANs in ORBI RBR50
Message 2 of 5
ShadowHead
Tutor
Ok, thank you. Looks like it is not really VLAN support in ap roper way, just a 1 VLAN passthrough for IPTV. Thank you, wish I asked sooner. Wasted about 6 hours "playing" with this, even decending into Wireshark to take a look at the packets.
Message 3 of 5
Guru
Good luck.
Message 4 of 5
HomerMitchell
Exactly what I needed! You just saved me several hours. Thanks!
mcdvoice login
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2424 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
