Orbi WiFi 7 RBE973
Reply
Change Orbi Login User Name to Something other than 'admin'
GregBl
Hello,
I have an Netgear Orbi Mini AC2200 RBK22.
Is there a way to change login user name to something other than 'admin'?
Thanks!
Message 1 of 5
Accepted Solutions
Guru
Re: Change Orbi Login User Name to Something other than 'admin'
No, you can't change the login name. Only the password
Message 2 of 5
All Replies
Guru
Message 2 of 5
CrimpOn
Guru
Message 3 of 5
SW_
Prodigy
Prodigy
A friendly WARNING!!!
If you're fearless and proceeding to change username "admin" to something other than "admin" via telnet, make sure there's a paper clip nearby.  The username "admin" is hard-coded in the firmware.
Message 4 of 5
GregBl
Thanks for the replies.  After doing some additional research I've decided to leave it as is.  The Telnet is not something I have experience in so I won't be going that route.  This is the  1st router I've had that I was not able to change it - so, was surprised.  Seems like it's not a big deal though - as long as I change the PW.  🙂  Thanks again for your help!
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 6622 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
