Tobold's avatar
Tobold
Connecting to an Orbi RBR50 when internet isn't working
I have an Orbi RBR50 system which used to work perfectly fine, until the modem provided my my ISP broke down and was replaced by a new model. Now the new modem (a b-box v3+) and the Orbi RBR50 seem to have some incompatibility, and the modem doesn't assign an IP address to the Orbi. So the Orbi doesn't have internet access, and when I use the Orbi app, the app gets stuck and tells me that there is no ethernet cable connected to the Orbi (of course there is).
Now I would like to use orbilogin.com to change settings on my Orbi and maybe fix the problem. However, when I connect to the Wifi of the Orbi via my iPad, the Wifi shows up as "no internet connection". And because of that, using a browser to connect to the Orbi via orbilogin.com doesn't work (Error message: "Safari cannot open the page "http://orbilogin.com/" because your iPad is not connected to the internet. And as I already said, the Orbi app doesn't work either.
I tried to connect the Orbi with an ethernet cable to a PC laptop. But when I surf to orbilogin.com, it tells me that I am not on an Orbi Wifi.
So how am I supposed to change the settings on my Orbi?
  • FURRYe38's avatar
    Power OFF The ISP Modem for 30 seconds then back ON. Press the reset button in back of the RBR for 15 seconds then release. Connect a wired PC to the back of the RBR and using a web browser walk thru the setup wizard at 192.168.1.1 or orbilogin.com.
    Does the modem have a built in router already? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    • Tobold's avatar
      Tobold
      #FURRYe38 Thank you for the tips.
      I spent a whole day already following different variations of the modem reboot / Orbi reboot sequence. Nothing helped.
      Yes, the modem has a built in router already. And very few accessible settings, seems to be kind of hardwired by the ISP. I'll try the AP mode on the Orbi once I manage to connect to it.
      Connecting to 192.168.1.1 gets me to the settings of my modem, not the Orbi. Orbilogin.com doesn't appear to be working either. I think somewhere in the process the internal IP address of the Orbi automatically changed, but I don't know to what exactly. I think it started with a 10.
