SpikeB
Oct 07, 2018Initiate
Daikin Wifi
I am trying to connect a Daikin WLAN adapter through my Orbi mesh but for some reason my Orbi is not being found. Seeing as all of my neighbour's WiFi routers show up, I guess the error is somewhere in my Orbi set up.
Any ideas.
Any ideas.
- Brilliant, thank you very much, got there in the end.
I'd already tried using Channel 11 but with no joy so I thought it was something else. I don't know if that's peculiar to my set up though because I moved out to 6 and it's working perfectly.
Thanks again.
What FW is currently loaded?
Do other devices connect to the Orbi? If so, then this particular adapter maybe the problem.
Try this, Temporarily disable WPA security settings on the Orbi then try to see if the adapter sees and connects to the Orbi. If so, try setting WPA and TPIK and test. Then try WPA2 and AES only.
Ensure the adapters drivers are up to date.
- Blanca_ONETGEAR Employee Retired
We’d greatly appreciate hearing your feedback letting us know if the information FURRYe38 provided has helped resolve your issue or if you need further assistance.
Blanca
Community Team- Blanca_ONETGEAR Employee Retired
- SpikeBInitiateBrilliant, thank you very much, got there in the end.
Thanks again.
